Re: Farmall H starter
Posted by teddy52food on May 01, 2011 at 08:06:59 from (68.169.216.43):
In Reply to: Re: Farmall H starter posted by SadFarmall on May 01, 2011 at 05:56:26:
Good fitting bushings are important too. If they are worn it will let the armature drag on the field poles . It needs heavier cables if yours are getting hot.
