Re: 300u fast hitch leveler
Posted by old on May 01, 2011 at 11:18:24 from (4.245.8.113):
In Reply to: 300u fast hitch leveler posted by mike paulson on May 01, 2011 at 05:04:02:
I have ran into that problem before and what I did was drilled a hole then put in a roll pin. Works well and is cheap and doesn't look all that bad either is you use the correct size pin it is tight and a person has to look close to even notice it
