Re: 140 Farmall touch control
Posted by MK in Ontario on May 01, 2011 at 12:32:20 from (70.54.105.86):
In Reply to: 140 Farmall touch control posted by Mel Thomas on May 01, 2011 at 06:06:42:
I think GriffNC meant on the left side of the touch control hydraulic unit/tractor, below filler hole. You may be right about relief valve. Also, make sure the linkage is fine between control spool and actuating piston rod. Does it do it in both directions of movement, in any position or just at extremes and on both spools? Maybe one just got out of adjustment.
