Re: cost for machining an A crankshaft
Posted by John M on May 01, 2011 at 14:27:29 from (67.231.169.173):
In Reply to: cost for machining an A crankshaft posted by bkpigs on May 01, 2011 at 13:21:51:
Most around here charge by how much has to be done to it. Last one I had machined was 150, but it had to be taken down a good bit on the mains.
