Re: need Ohms law advice...
Posted by gregk on May 01, 2011 at 18:27:43 from (75.105.32.38):
In Reply to: need Ohms law advice... posted by mike paulson on May 01, 2011 at 18:12:33:
You can charge your 8 volt battery on 12 volts but it will still only put out 8 volts. Shouldn't hurt it if it's on a low amp rate and you keep an eye on it. The thing to look out for is if it is boiling out the acid from too "hot" of a charge. remember a car alternater may charge at 14 to 15 volts for a 12 volt system and that is normal.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
