Re: 806 locking brake issue..Long...need help...still
Posted by mazemeister on May 01, 2011 at 19:48:15 from (24.188.81.230):
In Reply to: 806 locking brake issue..Long...need help...still posted by Dave from MN on May 01, 2011 at 16:05:33:
never experienced this one... but first thing i would do is pull that return line from the power brake valve and make sure oil comes out when you start up the tractor. also maybe put the air hose to the tractor end and make sure it"s a clear run into the reservoir. don"t know if a blocked dump line would cause your symptoms but.
i forget, is this a problem that just suddenly started? or new to you tractor? what else has happened to the tractor since it worked right?
