If the pressure hose is capped, the other hose will continue to leak out fluid if (and really only if, the piston is bypassing and the door is going down on its own. The bottom half of the cylinder has no ram shaft going through it and because of this it is not equal displacement end to end. As the fluid leaks, the upper (ram side) gets more and more fluid in it, but the piston is moving down, making more room, because the ram shaft is also entering this space, the fluid will come out of the non pressure hose. To be an equal force two way cylinder, the cylinder needs to have a rod coming out of both ends. (there are those made to operate that way) The oil coming out will not be as much volume as might be expected, but it will come out as it settles. If the door stays put exactly where it rests when the support is removed, (it may sag a little, then stay exactly still, the cylinder is good. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
