Re: wide front end
Posted by Albo5000 on May 02, 2011 at 05:30:16 from (76.9.110.206):
In Reply to: wide front end posted by James K on April 30, 2011 at 07:54:22:
I have a Super C with wide front that i want to convert to a narrow. The wide is a little beat up but works just fine. If you wanted to set up some sort of swap we could make arrangements. I have been told that the C, Super C, B, and BN all use the same front end components.
