Posted by janicholson on May 02, 2011 at 06:45:07 from (199.17.6.77):
In Reply to: Farmall B advise posted by 4 bottem on May 02, 2011 at 05:11:24:
I agree with Stewart. A distributor from the same sized engine class (A,B,SA,C,SC,100-240 and others)will be fine. Use a 12v no external resistor required coil (cheap) at NAPA or others. Change the ignition setup to include a new switch (the old switch can only ground a mag, not switch battery voltage!). The standard switch is available, or you can put a key switch in it. A simple on off two terminal switch is fine for operation, and makes a little better security. Get the ignition circuit voltage from the load side of the amp meter (not the side connected to the starter switch. (if any)) Use 0gauge cables and soldered on terminals for the starter. Good luck, and ask questions if needed. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
