Posted by janicholson on May 02, 2011 at 06:57:26 from (199.17.6.77):
In Reply to: H farmall posted by Jerry RV on May 02, 2011 at 06:50:57:
15-40 diesel spec. oil is just fine for that gas tractor. They start well with the multi wt, and like the thicker run temp viscosity. Most of us on the forum use either 10-40, 10-30, or 15-40. All of todays oils are so much better than any oil of the past, that if it is a brand name, it will be fine. I always took 8 quarts out to do the change, and had some left over to add later. (with filter) Dig out the old filter square section seal in the groove under the filter canister. It takes a dental pic or sharp ice pic to get at the hardened rubber. When getting a filter, make sure to get that seal (square section Oring) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
