1466 starting problem
Posted by Larry B 1486 on May 02, 2011 at 07:29:43 from (173.190.62.53):
Having trouble starting my 1466. If I leave it sit for three days or more it will not start without starting fluid. About four weeks ago I tryed useing the primer pump on the injector pump to see if that would make a difference. Started right up. When working the plunger up and down lots of fuel came up around it. Am I loosing prime around the primer pump? Don't that plunger turn out? Maybe a O ring or seal gone bad around it? Also noticed when the tractor is running, dripping fuel from a return line from a injector. Could that have anything with loosing prime after it sits for a few days?
