Re: 504 IH tractor hydraulics
Posted by karl f on May 02, 2011 at 12:46:15 from (209.188.106.159):
In Reply to: 504 IH tractor hydraulics posted by Monroe Stephenson on May 01, 2011 at 20:02:36:
Should be same as our 656. You just use it. Select the correct coupler so that the lever cannot accidentally get put into float position when you intend to raise. for lowering, it is probably better to push into float position, but the brief time should not hurt the relief valve if you don't utilize float. If concerned, a hose to dump into the reservoir can be connected to the unused coupler.
karl f
