Posted by M Diesel on May 02, 2011 at 16:11:48 from (12.24.61.12):
In Reply to: 450 Diesel posted by labman98 on May 01, 2011 at 20:01:24:
I don't think I've ever seen white on an injection pump, but have seen white primer on several diesel blocks. Numbers on the pump tag can determine it's original use.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
