Re: Just bought a 49 M
Posted by soybeanjoe on May 02, 2011 at 18:20:01 from (66.213.171.108):
In Reply to: Just bought a 49 M posted by greener351 on May 02, 2011 at 18:03:21:
No big deal as long as it had a resistor between the coil & points to keep from burning them. Even then worst would be the points would burn shut &you'd have to replace them. Bigger problem is that the 6v generator won't keep the battery charged so you'll have to recharge it often.
I've seen several tractors settup that way. In fact the SMTA I bought a few years ago was that way. One thing is that the 12v battery will turn it over a lot quicker. Won't hurt the starter as long as you don't "grind away" on if it won't start
