Re: Farmall H starter
Posted by Chris Sw on May 02, 2011 at 18:41:34 from (174.54.5.1):
In Reply to: Farmall H starter posted by Chris Sw on April 30, 2011 at 20:21:02:
Thanks for all the great advice, I looked at the wiring and found that the wire going from the starter button to the starter was only a 4 gauge. I replaced it with a 2 gauge and she fired right off. Now just need to get the packing nut figured out on the water pump...brand new pump and everytime i shut the tractor off my packing nut is loose.
