Re: Farmall Regular front wheel bearings
Posted by magneticanomaly on May 02, 2011 at 19:11:38 from (70.100.193.205):
In Reply to: Re: Farmall Regular front wheel bearings posted by J.J. from Afton on May 02, 2011 at 08:37:02:
I have the seal books.
The problem is that the original design does not provide a cylindrical spindle surface in the same plane as a hub counterbore, like modern units. The felt bears on a radiused surface of the spindle. I suppose I could make a bushing with a tapered ID to span this area and provide a cylindrical OD for a standard modern lip seal to run on, but I am womdering if others have solved this problem.
