Re: how to set up plow
Posted by stanhoist on May 02, 2011 at 19:17:11 from (74.33.70.11):
In Reply to: how to set up plow posted by tooltimejim on May 02, 2011 at 18:41:56:
Furrow tire should be set 1/2 width of plow cut plus 1/4 of the bottom size from center plus 2", if this can not be obtained split the difference between tractor and plow, place land wheels of tractor on blocks the depth of plowing and level plow, set tailwheel/skid so landside runs 1/2" from furrow wall, set suck of bottoms so back of landsides run 1/2" from furrow bottom, set colters so they cut at less 1/2" wider then the bottoms, or find an old plow manual and these settings should be close, going from memory and you know what they say about that, good luck
