Re: Re: Re: Re: Re: Re: 400 ? again.....where to add T.A oil?
Posted by RickB. on July 30, 2000 at 11:37:15 from (205.231.149.33):
In Reply to: Re: Re: Re: Re: Re: 400 ? again.....where to add T.A oil? posted by Rich (ks) on July 30, 2000 at 09:48:03:
Big D has a 460. There are differences there, one being the hyd pump is in the rear frame, not engine driven like the 400/450. Maybe the oil has to be thrown over a web in the case by rotating gears, therefore the front drain plug??? That web would also keep the front section from oil-starvation on steep hills, and low oil levels. JMHO.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: 400 ? again.....where to add T.A oil?
