Re: converting cub to 12 volt
Posted by SouthernFarmall on May 04, 2011 at 09:03:55 from (76.4.24.140):
In Reply to: converting cub to 12 volt posted by tomato frank on May 03, 2011 at 20:24:13:
If the 6 volt system doesn't want to crank, you ought to put larger wires on first. I would go to at least 1 gauge, maybe larger.
SF
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
