That is what this board is for, different opinions. I disassemble air cleaner, no easy job but only way to clean them. You can pull them behind the Queen Mary all the way to England and they will still have straw and crud that will never come out. I drill the spot welds and then resolder them. Trick is to get the elements to fit inner and outer edge nice and snug so no channel on edges. Some older air cleaners have layers of different size mesh screen but all later ones have a rolled up mesh about 40 feet long. One thing I never do is tell some one what to do with his equipment, I tell them what I do and they can decide.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
