The 6 volt systems didnt crank over at any real fast RPM to begin with (depends on temp of course) but if the battery is stong and a heavy rated unit and you use 00 gauge Battery n Starter n Ground cables, a decent H should start okay if the battery n starters in decent shape.
First thing Id do is remove, clean n wire brush, n re attach all battery n starter n ground cables and make sure the battery is good n see what happens and replace the cables with 00 if they happen to be thin and wimpy...
A bad resistive burned starter switch can cause poor cranking also, even if all else is fine, you may wanna take a look at that possibility.
If you only put 6 volts on a 12 volt starter it will crank slower then molasses in January.
You ask "If it is actually a 6v starter, will I damage it with a 12v battery?? "
ANSWER you probably wont damage it (12 on a 6 volt starter) just dont let it crank too long although it can be a bit tougher on starter drives.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
