Re: 100 oil pump question
Posted by janicholson on May 04, 2011 at 18:46:51 from (199.17.6.77):
In Reply to: 100 oil pump question posted by RWInd on May 04, 2011 at 18:35:56:
No. That is blow by and a ring issue usually. Try putting a teaspoon full of ATF in each spark plug hole, crank it to distribute the ATF, then put the plugs in and let it set for three days or so to loosen the rings. If it has just gotten worse over the years, it needs rebuilt.
If the ATF does no good (it will smoke when first started) rebuild is in order. Check the oil pump when it is torn down, it can cause low pressure. Jim
