Re: H fan belt adjustment
Posted by Bob M on May 04, 2011 at 19:05:23 from (67.240.171.41):
In Reply to: Re: H fan belt adjustment posted by Eric allen on May 04, 2011 at 18:41:56:
Eric - If the slotted end of the set screw is buggered and you have a welder try this:
Turn the fan so the set screw is on top (12 o'clock position)
Set a 1/4 nut on top of the set screw. Now fill the center of the nut with weld.
Let it cool for a minute or two then give the nut a couple raps with a hammer.
Finally use a wrench on the nut to turn the setscrew out. The welding heat and vibration from hammer taps will free the setscrew.
Tip: Replace the setscrew with a recessed (female) hex set screw. And apply anti-sieze to the screw threads before installing.
