teddy have you taken one apart. the needle valve that shuts fuel when float raises. If you look at the tip of that needle it is made of rubber or some sort of plastic. I just got done rebuilding one (Zenith).
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
