400 rockers lever oilers
Posted by bugspot on May 04, 2011 at 22:00:12 from (75.97.216.79):
How does oil get to the valve spring side? The lifters are getting plenty of oil from the journals and canals on top of the levers. On the spring side it"s stays dry. Should I run it longer or are there journals in the valve side of the lever that may be clogged that I can"t see? Thanks ...Tim
