Re: Continental engine hard starting
Posted by rustyfarmall on May 05, 2011 at 06:46:13 from (216.248.71.224):
In Reply to: Continental engine hard starting posted by jb706 on May 05, 2011 at 04:22:59:
Did you replace the float valve? Did you check the float for leaks? Is the float set at the correct height?
Don't rule out an ignition problem either. You may have a weak coil, or it might be over due for a good, general tune-up.
