Re: Setting Points 1958 IHC 560
Posted by kopeck on May 05, 2011 at 11:12:02 from (169.244.70.157):
In Reply to: Setting Points 1958 IHC 560 posted by 1940P-40 on May 04, 2011 at 00:28:43:
You want the points to be open when you set them, TDC would be (around) where they're closed.
Just rotate the engine until the points a furthest apart then set them to spec. It's not hard at all.
I noticed you said you were going to change the condenser but you didn't mention the points...change those too.
K
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
