Re: How to tell if my delco starter brushes are too worn
Posted by Owen Aaland on May 05, 2011 at 13:10:07 from (216.47.32.42):
In Reply to: How to tell if my delco starter brushes are too worn posted by Redwolf on May 04, 2011 at 18:31:01:
Generally they should be replaced before they are reduced to half of their original length. You want to make sure that they do not wear so much that the retaining screw head contacts the commutator bars. Without knowing what starter you are working on it is hard to give you a measurement. Gas engine starter brushes will probably be about 5/8" when new, diesels more likely about 3/4". I've got Delco replacement brushes here that range from 1/2" to a little over 7/8".
