Re: farmall 400 power steering problem
Posted by D Slater on May 05, 2011 at 14:07:42 from (184.15.26.40):
In Reply to: Re: farmall 400 power steering problem posted by aaron brown on May 05, 2011 at 11:33:22:
Between the support post and the first valve. Its just a small round solid plug that uses a oring. With PS the oil flow path is changed in the hydraulic system. Without the plug it will work as you describe. Could be something else but with just installed thats the first thing to ask about.
