Re: 140 won't turn over
Posted by CNKS on May 05, 2011 at 18:20:06 from (216.144.104.128):
In Reply to: 140 won't turn over posted by SouthernFarmall on May 05, 2011 at 17:01:56:
The battery could be bad, otherwise 99% of the problem is bad connections. You can usually start a C113/123 with a crank. With a weak battery, the starter takes all the electricity, leaving none for ignition. Clean up your connections, new cables if necessary, along with the battery.
