Re: Farmall B - Value and what to look for???
Posted by gregk on May 05, 2011 at 19:32:58 from (75.105.32.38):
In Reply to: Farmall B - Value and what to look for??? posted by Matt Weltz on May 04, 2011 at 21:50:11:
If they are like a c farmall(and they are in a lot of ways) watch for a cracked engine block from the oil pan on up or on the front by the distributor. Sometimes when used for mowing and they got bounced alot this would crack the engine block, my 1950 c is like that. My 46 B on the other hand I overpaid for but picked up a cheap woods 59 belly mower and couldn't be happier. As is stated earlier they are easy to get out of tight places, steer very easy, are easy to use for wagons since you can just lean back and pull the drawbar pin, and are just plain handy. Price wise depends where you are at, in NE they are uncommon as they were too small for alot of field work and the farms around here were 160 acres or more. I would say if the tires are OK maybe 500 or so.
