Posted by gene bender on May 05, 2011 at 20:17:36 from (207.177.56.53):
In Reply to: 140 won't turn over posted by SouthernFarmall on May 05, 2011 at 17:01:56:
When that happens first thing is always check to see that the starter isnt .ocked up on the flywheel . Put the crank in and see if you can turn the engine over if not remove the two mounting bolts after removing the batt cable then you can see if the starter drive needs attention. Check all batt connections even the starter sw.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
