Re: 706gas head bolt specs
Posted by LOU from Wi. on May 05, 2011 at 20:29:04 from (174.124.113.80):
In Reply to: 706gas head bolt specs posted by Joey1 on May 05, 2011 at 18:35:08:
According to the book,as follows for head torque."Torque all of the cylinder head bolts in two steps and in proper sequence. Torque first to 65 ft lbs.then retorque in sequence to full torque of 90 ft lbs.Back off 1/2 turn,one bolt at a time(in lengthwise rows) and retighten to 90 ft lbs. torque.Adjust valve lash."
If you start with the bolts placement on the head ,looking over head and from the drivers side. Numbers are as follows,from the front. 12-8-4-1-5-9-13. Passenger side from front(thermostat housing) numbers are as follows. 14-10-6-2-3-7-11-15.
According to the book, the valve lash should be .027 inch.
hope this helps.
Victor
