Re: english paper help
Posted by Sam#3 on May 06, 2011 at 07:21:16 from (70.129.186.38):
In Reply to: english paper help posted by andy stockmaster on May 05, 2011 at 17:23:21:
If it's just a paper find most any book on 'engines' and write it. If sources and acknowledgement are required it gets a bit tougher. Instructors sometimes check you work.
Use your spell and grammar checker because that's the point of writing the paper.
