Re: EARLY IHC Steel Wheels- ID and Value
Posted by Ron in Nebr on May 06, 2011 at 15:56:41 from (66.252.113.193):
In Reply to: Re: EARLY IHC Steel Wheels- ID and Value posted by oldiron29 on May 06, 2011 at 03:17:30:
These weren't "drive" wheels, the axle shafts themselves were fixed, in other words the wheels spin on the axles like there's a bearing or bushing inside them. The "center cap" thing, that's under the pop can in the picture, has a bolt going through it to hold it on the axle shaft. The "inboard" portion of the 3ft long axle has a keyway ground in it, probably 10in long....but of course I'm not positive those are the original axle shafts. Each wheel has(had) an identical shaft.
I'll try to get a closeup shot of the centers. Thanks!
