Re: Front-End Loader For 444
Posted by Owen Aaland on May 06, 2011 at 21:46:21 from (216.47.32.42):
In Reply to: Front-End Loader For 444 posted by kajun on May 06, 2011 at 10:18:48:
The IH 2000 and 2050 loaders were often installed on those tractors.
Are you sure that you hydraulic system has a 15 gallon capacity? Normal capacity of the hydraulic reservoir is 3 gallons. If you have a front mounted, crankshaft driven hydraulic pump the capacity can be increased by drawing the oil out of the transmission and returning it to the hydraulic reservoir. That option was normally only used on the 2444 models.
