Re: Need help with adjusting timing. 460 Utility
Posted by Owen Aaland on May 06, 2011 at 21:55:56 from (216.47.32.42):
In Reply to: Need help with adjusting timing. 460 Utility posted by pistoncan on May 06, 2011 at 06:09:13:
Like Pete says the governor only affects timing in that it need to be correct at high idle speed. The adjustment of the point gap does affect timing so the points must be set first. Adjust the timing after the points are set and then adjust the carburetor last.
