Re: 300 Utility clutch replacement
Posted by Janicholson on May 07, 2011 at 21:36:00 from (64.61.211.66):
In Reply to: 300 Utility clutch replacement posted by petertay on May 07, 2011 at 18:18:07:
I will add to Danny's info/
The TA clutch could be changed at the same time. Replacing the TA one way clutch at the rear of the TA is also good preventive maintenance. It ,ight not have a TA, but most did.
The Flywheel has a step depth between the Pressure Plate mounting surface, and the friction surface.
Make sure that is in specification when machinind the Fly Wheel. Jim
