Re: MD disel starting issues
Posted by Janicholson on May 07, 2011 at 21:52:00 from (64.61.211.66):
In Reply to: MD disel starting issues posted by KluegCollector on May 07, 2011 at 15:30:13:
Take the pump apart again. The thing isn't that difficult to work on. Be clean, take pictures, and look for stuck components, or worn parts. The rack and plunger can be stuck. The pressurizing pump can have its pressure relief stuck. Jim
