Posted by Tom Fleming on May 08, 2011 at 03:02:03 from (67.20.243.240):
In Reply to: farmall a posted by m smith on May 07, 2011 at 19:47:36:
fuel delivery sounds like your issue. clean all the components of your fuel system. that would include screen on the sediment bowl, check inside the tank, and make sure the inlet to the sediment bowl isn't plugged or restricted. Sounds like you have crud or varnish somewhere. IF the main jet is plugged or restricted, same answer.
Clean fuel delivery components and rebuild the carb.
Only other thing it MIGHT be is a leaking intake manifold gasket.
Try these things and tell us what you find. And don't be intimidated by a carb rebuild if you have never done one before. The carb for the C-113 (A, B, BN, C) is one of the more simple ones.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
