Re: farmall a
Posted by blunted on May 08, 2011 at 09:53:27 from (205.188.116.73):
In Reply to: farmall a posted by m smith on May 07, 2011 at 19:47:36:
tom and old are both rite. also if you dare, remove th valve cover and check the torqh on the head bolts, and vave clearance. manifold nuts can be loose too. mark
