That engine will run on diesel cycle if you show any pressure at all on the primary pump gauge. May not have any power but will run. What part of the pump did you take apart, primary or high pressure. Did you adjust injection nozzle pressures to about 700 psi. Will it shoot a good stream out of injector bleeders when running on gas cycle and with some throttle. Make sure the decompression valves are not all stuck open. You can tell that easily by removing the spark plugs and cranking engine over on diesel cycle with starter. If they are closed and sealing no compression will come out of spark plug holes.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
