Re: Max pto speed on MD
Posted by pete 23 on May 08, 2011 at 19:32:16 from (74.44.100.190):
In Reply to: Re: Max pto speed on MD posted by sflem849 on May 08, 2011 at 19:17:07:
Yup, got that settled, now the problem is that a lot of mfg's including IH strayed away from rated engine speeds meeting std pto speeds. One example is an 806 Diesel with a rated engine speed of 2400 rpm, max high idle speed 2640 and std pto speed of 1000 rpm or 540 rpm at 2100 engine rpm. You had to set a dyno to read at 1146 or 616 ( if memory serves me correctly) to check horse power at rated engine rpm. Led to a lot of incorrect dyno readings and lots of complaints about pto horsepower. They switched back to rated and std on the 50 series. I have no idea what the new ones are. Not my problem anymore.
