Re: Re: Re: Re: Re: Re: Re: Re: Re: 400 ? again.....where to add T.A oil?
Posted by Rich (ks) on July 30, 2000 at 22:29:08 from (209.64.118.202):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: 400 ? again.....where to add T.A oil? posted by Wardner on July 30, 2000 at 21:27:22:
It didn't seem to make any difference in mine. Everything except the hydralic system resevoir for implements was yellow oil.....I let it set for a morning and then the first thing out was a bath of water from the rear end and then here come that yellow murky mix and then came some clear. I can gaurantee you I was not expecting pure water when I first pulled that plug.
Another thing I'd like to know now as well.....That water had to be in there last winter and there was a few days it got pretty cold. How was I able to still be able to drive it? I was told those bull gears run really close to the bottom of the housing and if that's the case it should of froze up.....don't you think?
I'm just glad I finally got all that yellow murk out of there. I think I've got that tractor to a solid trusting point now!....Thank god for ytmag....very imformative site.
Thanks for the help again
Rich
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 400 ? again.....where to add T.A oil?
