Posted by pete 23 on May 09, 2011 at 10:01:05 from (74.44.100.190):
In Reply to: 1957 Farmall 450 posted by craig reavley on May 09, 2011 at 09:26:14:
The idle jet is the long one sticking up from lower carb bowl inside carb and has a very small hole, number 72, 74 or 75 which measure out to about .022 of an inch. Idle mixture screw is one near carb mounting base setting at a slight angle, idle speed is one where gov connects to carb and the main jet adjusting screw is bottom one with packing nut . Turn main jet out at least 3 l/2 turns and others where idle is low enough and smoothest.
