Re: Oil leak at the distributor on a 400???
Posted by oldts on May 09, 2011 at 21:19:15 from (63.233.243.94):
In Reply to: Oil leak at the distributor on a 400??? posted by 43warhorse on May 09, 2011 at 20:23:05:
Cory, you will need to change the seals in your pump. You will have to remove the pump,be sure to change the one on the drive gear end of the pump too. After re-installing the pump you will have to retime the distributer.
