Re: Cracked head on a MD
Posted by D Slater on May 10, 2011 at 03:56:21 from (184.15.26.40):
In Reply to: Cracked head on a MD posted by Brad in WI on May 10, 2011 at 03:01:36:
Won't tell you much, with the starting valves open pressure will go past the rings. With starting valves closed to check the starting chamber the pressure will leak past the valve.
Pressure check of the cooling system may tell if there's a leak somewhere in the system. With a old radiator limiting pressure and a cold engine it would be a long shot finding anything.
If you work the tractor hard and it starts pushing coolant from the radiator thats a good sign, also after the tractor sits 24 hours after working it crack the oil pan drain plug enough to just drip. Look for any antifreeze in the first drips. Or you can just say its cracked and be right more often than not.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
