Re: Farmall M Fan noise
Posted by John M on May 10, 2011 at 18:10:27 from (67.231.169.173):
In Reply to: Re: Farmall M Fan noise posted by Sammy in Kansas on May 10, 2011 at 15:42:26:
You probably have worn bearings. You trighted the belt up and it pulls down on the pulley just enough to hit the shroud.
