Posted by Jim Becker on May 10, 2011 at 19:12:52 from (173.57.144.251):
In Reply to: ethenal posted by Alan Harmon on May 02, 2011 at 19:16:37:
The amount of water that gasoline or a gasoline alcohol blend can hold depends on temperature. If the mixture is saturated and the temperature subsequently reduced, there will be phase separation with the excess water settling to the bottom. The lower the temperature, the less water need be present to have phase separation. Even at 0 degrees, an E10 blend can hold more than 0.3% water without phase separation. Properly handled and stored gas will not have that much water in it.
Adding a 12oz bottle of methanol when you put 20 gallons of E10 in your tank, will run the total alcohol content from 10% up to nearly 10.5%. That will let the fuel hold a little more water, or equivalently bring the temperature of phase separation down a little. But if your fuel is that contaminated, you have other problems.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
