Just keep in mind that lean is mean . and when the engine is not getting what it needs then the gov. tells the throttle plate to open wider . Tune it like your going to work it . Go thru every thing and be dead on with all your settings . Pay close attention to valve set and look at the wear on the rockers , Don't try and get the whole feeler gauge between the rocker arm and the valve stem as this gives a false reading and set . Check the timing of the engine and make sure that the advance is working . As to setting the carb myself i would set it at 4-4 1/2 turns off the seat and get the ideal set as low as i could and get it as smooth as i could then set it back up to the correct ideal RPM's setting a carb is sorta a knack that comes from just doing it .. Is your carb wore yep more then likely comes from to much field testing when new. Everybody worrys about how much fuel they burn . A tractor will burn fuel they were not fuel sippers . Ya want something that sips fuel then get a Old 400-450 Diesel or a 720-730 Deere a David Brown . look at the size of the fuel tanks and that will sorta tell ya how much fuel a tractor will eat in a day , all but and old M that we had put twenty gallon in at the start of the morning of picking with a two row mounted and it would tell ya when it was lunch time as it was out of gas. Put twenty more in it and it would tell ya when it was time for supper . She would suck down twenty gallon in four hours five gallon and hour picking corn .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
